ford69557ci wrote:At the moment i run a 64-71 s300, ddp stage4 sticks, non ic with a 3.5" crossover pipe, bumped timing, no afc, maxed fuel screw, holley blue pump with bypass regulator, 3/4 fuel pick up with 1/2" fuel lines, frieghtliner fuel filter setup. 2 nozzle nx nitrous and snow stage 2 w/m. not sure what kinda power but 4x4 burnouts and 2wd 5th gear burnouts from 70mph are no problem. oh yeah also a custom pulling dual disk and 3.54 gears.
6LCummins wrote:I have 3.73 in the rear end and 3.54 in the front end. Im looking to get both axles to have the same gears. The reason why there are 2 different sizes is i grenaded the original rear end that had 3.54 gears in it. So im running 36.5 inch tires and 3.73 in the rear end and have to work to get it that hot.
6LCummins wrote:i dont have a corp 14, my rearend is a Dana 70HD. thats how i can get the 3.54 gear ratio.
Bookshelf wrote:6LCummins wrote:i dont have a corp 14, my rearend is a Dana 70HD. thats how i can get the 3.54 gear ratio.
So you have a dually rear then? Or did you swap in a srw rear from a different truck? Your sig says srw/drw.
