Fine then, I'll do it.
I was on the phone earlier.
Zero Buck ModsAs long as you're aware of the potential of runaway when you're fiddling with the fuel screw there's really not much you can tear up in the actual modding process. You may break the little AFC line that goes to the head, but that's about it.
After the modding is when you tear stuff up.
Oh, and with my factory non-IC'd sticks, cranked pump, LPLP, BHAF, 4" exhaust and an S362, I put 268 horse down through the Getrag. Auto numbers will be anywhere from 20-50 hp lower depending on the condition of the converter.
