by U.S MMA » Fri Sep 02, 2011 8:01 pm
i also have been shooting for a functional tow rig, although not at the power level you are shooting for. A custom intercooler and rad should definatly be in the order. I think a hellman cooler is around 1200, im not sure if they do radiators, but that would be the shiznit. Maybe those 5x10 southern diesel extreme's, Ive found good reviews on those. As everyone has stated, different parts of the country require different things out of a truck. Up here, grossing about 15k, cab over, trailer with 4 sleds and gear, I can pull 7-8% grades all day at 60mph, not fast nor heavy i know, but in commifornia where i came from, id be limping up a hill in 3rd at 40 mph with that load. 20 degrees vs 90 or worse.
90w250,5spd,flatbed,dually swap, power lock ,kelderman, fresh trans rebuild, valair stocker,newer 9leaf,2"skyjacker
3200,60wheel65 16 pacbrake,60exhaustsprings,93 head, snowstage3,
custom bumper broken winch,topboxes,underboxes. J&H helped out a lot. slowly restoring(real slowly)
