by JimmieD » Thu Oct 03, 2013 10:27 pm
Sometimes it helps to crack 3 injectors loose [1-3-5], leave 3 tight [2-4-6], crank engine till it acts like it wants to start. Then tighten the loose injector lines, loosen the others and crank again, till it acts like it wants to start. Then tighten all, crank and let her run.
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
