Hi, i noticed a strange thing recently, when i push the brake and the truck slows, the engine speed rises approx. 100 rpm.
even if i'm rolling very slowly in 1'st gear, and make a quick stop this will occur, as soon as the truck stops, the rpm's return to normal, this happens both in gear and in neutral, and when i reverse and brake, the rpm's drop about the same, this phenomen seems to be created of the inertia force, probably acting on the governor weights in the pump, as it is longitudally mounted, but is there anybody else out there that has noticed it?
