Got my front cover off a few minuites ago. The KDP was about .140 below the aluminum casting surface. I took a brass
1/4 inch rod and a hammer and gently bumped up against it about 3 times and measured again. Now it reads about .170 in.
I have to think it was a matter of time till it would have worked its way out. ! Don't know if it would have been a month - a year or 5 years......
I would say- as easy as it was to get to - don't let it slide !
I looked through a small gap into the crank /pan area with my LED flashlight...... There is NO dirt or sludge to be seen !
The oil I first drained out of it looked like coal dust------- Impressively clean for 1 oil change and
running about 4 hours !
Oil Pan is next........
What say the Mob ? do I use a factory gasket on the front cover ? I got the old one off in 1 piece ! how would Victorflex
do for making a duplicate ? And if I used Victorflex what sealant to go with it ? or should I use a thicker more cushoney gasket with no sealant added ??????? or just factory replacement ???????
Tim !
