Engine Mount - Motor mount installation
Postby wilkyflex » Wed Jan 07, 2015 11:39 am
Does anyone have instructions and pictures of the correct way to install engine mounts in a 1992 dodge D-250?
Thanks
Dean
wilkyflex
Re: Engine Mount - Motor mount installation
Postby simplysmn » Mon Jan 26, 2015 8:54 pm
The little nub goes tward's frame side.If you are changing them out then leave them both loose till you get the Motor set in right .Then Tighten them up.
simplysmn
