HELP put gas in diesel truck
Postby jdaivs1 » Fri Feb 06, 2015 8:10 pm
My niece accidentally put about 7 gallons of gas in my diesel. Can I just fill the tank with diesel and go? I read some where of people mixing gas and diesel just can't remember where? (93 w250)
93 w250 auto, fuel screw turned in
jdaivs1
Re: HELP put gas in diesel truck
Postby RCCUMMINS89 » Fri Feb 06, 2015 8:24 pm
Not with 7 gallons.... drain it. I did it once on my RC.... just pull the line right at the lift pump and pump it out through that. I used a little squeeze bulb to get it going and let it gravity feed into tanks.
Postby jdaivs1 » Fri Feb 06, 2015 8:52 pm
Thanks. By the way my rebuilt stock injectors work great!
jdaivs1
Postby RCCUMMINS89 » Fri Feb 06, 2015 11:01 pm
Glad to hear. Was it driven much after, or was it caught right at the tank?
I caught mine while I was doing it (going hunting at 2 in the morning, was tired). Much drive time and potentially can damage the ip.
Postby jdaivs1 » Sat Feb 07, 2015 12:55 pm
Driven about 8 blocks and died. Hmmm ya rebuilt injection pump was put on last year if I remember right.
jdaivs1
Postby RCCUMMINS89 » Sat Feb 07, 2015 2:11 pm
Ya, that's not good. My bet is the ip crapped out.
