Low vaccum sensor
Low vaccum sensor
Postby Michael Yankovitch » Mon Feb 16, 2015 5:05 pm
Does anyone know where I can buy the "low vacuum sensor"? I tried NAPA and O'Reilly's websites. Just curious if this is a hard to find item.
Circled below in yellow:
(In progress project)
1978 GMC body swap onto 1991 non-ic Dodge W250 4x4 (A727, np205, D60 & D70 with 3.07s)
Full de-computerize. Removing PCM and simplifying wiring to its most basic form.
Michael Yankovitch
Re: Low vaccum sensor
Postby bgilbert » Mon Feb 16, 2015 6:01 pm
Taken from your signature, "Full de-computerize. Removing PCM and simplifying wiring to its most basic form.", I would think you would just eliminate the thing. I wiped my a$% with it years ago when I did my crew cab conversion. Haven't had a problem. If you just have to have it, I would try a want ad, junkyard or the Dodge dealer.
Bill Gilbert
Postby Michael Yankovitch » Tue Feb 17, 2015 3:47 pm
bgilbert wrote:Taken from your signature, "Full de-computerize. Removing PCM and simplifying wiring to its most basic form.", I would think you would just eliminate the thing. I wiped my a$% with it years ago when I did my crew cab conversion. Haven't had a problem. If you just have to have it, I would try a want ad, junkyard or the Dodge dealer.
I was thinking it was a good first warning to brake problems. I am very tempted to get rid of it....
Michael Yankovitch
