91 fuel filter delete
Postby 93cummins89 » Sun Oct 25, 2015 8:54 am
Ok I want to get rid of my filter that hangs in the side of the motor. Can some one point me in the right direction to what o need to block it off or is it ok to leave open. Also where can I get shorter bolts for the lift pump block plate. If you haven't put it together I'm finally installing my fass with suction tube and fuel heat kits
93cummins89
Re: 91 fuel filter delete
Postby DMan1198 » Sun Oct 25, 2015 10:54 am
Any place that sells bolts should have the bolts you're after (I want to say they're m8 course thread) I'm fairly certain you can just leave the whole filter bits open (if you ever think you might go back to that stock setup plug the holes I guess)
Postby 93cummins89 » Sun Oct 25, 2015 11:30 am
thanks
93cummins89
