Valve cover breathers
Postby fatty » Sun Mar 24, 2019 11:20 am
Who on here uses the valve cover crankcase vent system? I put a billet tappet cover on a while back not realizing I would need to redo the crankcase vent. Is one set going to be enough or will I need to do something with the tappet cover vent also? My plan is to get some plugs for the tapper cover holes and only use the valve cover vent if that will be sufficient.
https://puredieselpower.com/dodge-produ ... combo.html
Re: Valve cover breathers
Postby ellis93 » Mon Mar 25, 2019 9:46 am
fatty wrote:Who on here uses the valve cover crankcase vent system? I put a billet tappet cover on a while back not realizing I would need to redo the crankcase vent. Is one set going to be enough or will I need to do something with the tappet cover vent also? My plan is to get some plugs for the tapper cover holes and only use the valve cover vent if that will be sufficient.
That is high as hell! Pete got me two of them years ago for much less. Pm him
Postby PToombs » Mon Mar 25, 2019 4:25 pm
Shhhhhhh! I was going to stay undercover on this! ;)
Postby BC847 » Mon Mar 25, 2019 4:57 pm
Shoot! I run two of those in addition to the 24v vent on the front of the gear-case. :oops:
But yeah, that's kinda high. :shock:
Postby fatty » Mon Mar 25, 2019 6:45 pm
Well they have an option a little lower down on the page for the same thing but not OE Cummins parts. That one is $179 with new gaskets so that's what I'd do.
I guess I'll just get 2 of them and see how it goes. Unless Pete's are even cheaper and he is willing to help me out. Pete? What do you say?
Postby PToombs » Tue Mar 26, 2019 5:27 pm
Mine are a little cheaper, about 150. I need to recheck prices on them, it's been a while and I know they creep up. Are you sure you need 2?
Postby fatty » Tue Mar 26, 2019 9:48 pm
No but I might as well just for peace of mind. I'd hate to have to buy another one later on.
