Who on here uses the valve cover crankcase vent system? I put a billet tappet cover on a while back not realizing I would need to redo the crankcase vent. Is one set going to be enough or will I need to do something with the tappet cover vent also? My plan is to get some plugs for the tapper cover holes and only use the valve cover vent if that will be sufficient.
https://puredieselpower.com/dodge-produ ... combo.html
