My turbo upgrade
My turbo upgrade
Postby mhuppertz » Sun Jan 31, 2021 7:15 pm
A few months ago my turbo suck in my BHAF and trashed the compressor wheel. It was a 60mm H1C hybrid with a 16cm non-wastgated turbine.
I sent it to Gillett in Utah (great guys) and they upgraded it to the max, a 62mm / 86mm.
The problem is, now the 16CM doesn't create enough drive pressure at lower RPM's now. Crazy, I never expected that. Now it will rev like crazy and is still pulling like a Viper at 90 when I shift into 5th!!!
So now I am saving for a floating 14CM. They are stupid expensive compared to the 16CM!
Anyway, thought I would get y'all caught up.
-Mark
MARK
'93 W250, HTT Stage IV/16cm, POD's, cut AFC pin, Pump advanced, Pyro, Boost, Fuel Pressure Gauges all non functional, burned wiring, 3/8” fuel line, BHAF on custom intake, 3,200 Spring, ARP Studs, New Head at 392K, Detroit Locker, NV4500, other stuff…
mhuppertz
Re: My turbo upgrade
Postby dazedandconfused » Fri Feb 26, 2021 8:54 am
I'm guessing this is what a lot of companies are building now as stock appearing turbos. Sounds like a nice upgrade.
