Bookshelf wrote:I'm sure putting a set of big injectors in would cause more of a pressure drop. I think it was DPuckett or wannadiesel that made that statement.
KTA wrote:I see no problems with using a second gen lift pump and a regulator, should work fine. The second gen lift pump supports around 400rwhp max properly, so you shouldnt have any problems with it supplying that setup.
sdstriper wrote:KTA wrote:I see no problems with using a second gen lift pump and a regulator, should work fine. The second gen lift pump supports around 400rwhp max properly, so you shouldnt have any problems with it supplying that setup.
If you buy a regulator, will you want one with a return feature, many do not have them?
