Well I've finally joined the RV club and bought a new camper....2700 dry and 3100 wet weight.
I figured I would do some PM's on the truck and install some gauges.....
So new air bags and rear end bearings......
But for the motor...I need to replace my cracked exhaust manifold....any benifit to use the newer style pulse manifold?
I'm debating about upgrading to a newer HX35 or 40 turbo.....the old WH1C is getting a lil shaft play and needs updating.
I'm going to upgrade to the newer style piston pump....hopefully it will let the VE keep on ticking.
The injectors should most likely be rebuilt or upgraded. Anybody have suggestions?
Thanks in advance
