Ater Installing Injectors??
Postby Mike T. » Sun Oct 07, 2007 6:51 am
After installing new injectors I noticed I had to raise/adjust my Idle speed,is this normal? Do new injectors run different after a period of time?
Thanks
Mike
93 w350 ext. cab,auto,354s,4"exh., smokey mt.,bhaf,htb2 62/65/12,CoolerTubz, ddp 55lpm inj.,Timed 1/8,Valet Switch,Piston LP,mild pump,3200 spring,ddp pin,Goerend TC,25k gvw trans cooler, deep pan,gauges,egt is pre.
Mike T.
Postby Mike T. » Sun Oct 07, 2007 9:27 am
I've also noticed that the engine doesn't idle as smooth as with the stock injectors.
Mike T.
Postby eyoung429 » Tue Oct 09, 2007 9:05 am
are they stock replacement ones? You may want to check and see if you have left one of the original copper rings in or pinched one.
1991 IC D350 2wd Dually,st cab, full 4in Magnaflow exhaust, 3.73 gears, auto 518,HX35....goin' to twins!!!
member of the cable pull club
eyoung429
Postby Mike T. » Tue Oct 09, 2007 5:23 pm
Thanks eyoung 429..
I think I found the problem :oops: me. When we took the old injectors out and saw the copper on the bottom, we thought it was the washers. When I took a closer look I realized it was just residue. I normally don't rat myself out but maybe this might help someone who pulls injectors for the first time. I just hope there's not an issue getting the two washers out.
Mike
Mike T.
Postby TWorline » Tue Oct 09, 2007 5:47 pm
Try a 90 degree dental pick, it should be easy to feel where the washers are.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby Mike T. » Tue Oct 09, 2007 6:37 pm
Thanks Tim..
Mike T.
Postby RumbleFish » Tue Oct 09, 2007 6:47 pm
TWorline wrote:Try a 90 degree dental pick, it should be easy to feel where the washers are.
If that doesn't work, you can still use it to get the left over lunch crud outta your teeth :wink:
Postby eyoung429 » Wed Oct 10, 2007 11:21 am
No problem Mike. I did mine at night and was in a hurry and couldn't figure out why the beast was stumbling so badly....missed 2 of them.
eyoung429
Postby Mike T. » Wed Oct 10, 2007 5:02 pm
If that doesn't work, you can still use it to get the left over lunch crud outta your teeth :wink:[/quote]
In my case it's bridges, fillings and crowns. :lol:
Mike T.
