2nd battery
2nd battery
Postby remi » Thu Jan 19, 2012 1:16 pm
has anyone thought about putting a second battery where the old air intake box used to be
1992 w250, a518, fuel screw borderline runaway, denny t stage 2 fuel pin, cai,4 turbo back straight pipe to 5inch stack, 4 inch lift, 3 and 1 boost, egt, tranny temp,
remi
Re: 2nd battery
Postby Hansen01 » Thu Jan 19, 2012 3:37 pm
thought about it,lol but i was to lazy to run it over than and just put em side by side on the drivers side
Under construction...
Hansen01
Re: 2nd battery
Postby remi » Thu Jan 19, 2012 4:53 pm
you got a pic of your set up
remi
Re: 2nd battery
Postby Tacoclaw » Thu Jan 19, 2012 5:04 pm
viewtopic.php?f=30&t=11059&p=83302#p83302
Had a couple minutes so I buzzed through his posts. 8)
Re: 2nd battery
Postby remi » Thu Jan 19, 2012 5:17 pm
problem is i put a damn semi battery in mine haha so there is no room
remi
Re: 2nd battery
Postby Hansen01 » Thu Jan 19, 2012 7:23 pm
Tacoclaw wrote:http://www.1stgen.org/viewtopic.php?f=30&t=11059&p=83302#p83302
;) thanks, and mine will fit parallel with the pickup, i had to turn them parallel to the truck when i put an intercooler in
Hansen01
Re: 2nd battery
Postby Diesel » Thu Jan 19, 2012 10:12 pm
remi wrote:problem is i put a damn semi battery in mine haha so there is no room
Well if you have an industrial battery you're ahead of the game. A semi battery on the stock tray shouldn't give you any problems. Heck these things start so easy you could probably just use a civic battery. Now if we had the 6.5 or a Duramax I would hope you had a couple batteries.
1991.5 D250 Intercooled A518
Diesel
