Throttle shaft leaking
Postby cummins32 » Sun Apr 15, 2012 8:38 am
My throttle shaft started leaking a few weeks ago, It quit for a while, but after I put my denny t fuel pin, in and it leaks like crazy lol. How hard is it to replace the gaskets.
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Re: Throttle shaft leaking
Postby cmann250 » Sun Apr 15, 2012 9:53 am
I resealed the top of the pump, only having a faint idea of what I was doing, in an hour and a half. If you can install a 366 spring, you're good to go. DGK121 is the reseal kit you'd need. It's about $20
Postby CumminsPower59 » Sun Apr 15, 2012 10:21 am
^X2. Take your time, there is a few little parts that like to grow legs and wander off. Pay close attention to how the throttle shaft is lined up, I used a paint pen on mine, worked pretty good. The top goes on a heck of a lot easier with the fuel screw backed out a lot, beats having to fanaggle it all back into place :lol:
Postby cmann250 » Sun Apr 15, 2012 1:37 pm
CumminsPower59 wrote:^X2. Take your time, there is a few little parts that like to grow legs and wander off. Pay close attention to how the throttle shaft is lined up, I used a paint pen on mine, worked pretty good. The top goes on a heck of a lot easier with the fuel screw backed out a lot, beats having to fanaggle it all back into place :lol:
Yes, this ^ too. If you bon't back the fuel screw out, you run a higher risk of breaking the arm it pushes on.
Postby cummins32 » Mon Apr 16, 2012 7:22 am
Ok Thanks guys, I ordered the kit last night, Do I need to take the pump off the truck ?
cummins32
Postby cmann250 » Mon Apr 16, 2012 8:04 am
Nope, if you just reseal the top
Postby CumminsPower59 » Mon Apr 16, 2012 8:06 am
As long as you are sealing up just the top, no need to pull the pump. ;)
Postby cummins32 » Mon Apr 16, 2012 8:51 am
Sweet, one more question lol, To index the throttle I, need to write down, where the marks are on mine and put them back in the same spot when I put it back together.
cummins32
Postby Rug_Trucker » Mon Apr 16, 2012 9:29 am
Digital cameras are a wonderful thing. Especially playing with carbs.
72 slant Duster M-1 2bbl Hookers
79 Maxivan Offy Comp RV cam0
74 Dart 225 4 DR
93 D350 CTD auto
various KW's and Freighliners with 10spd auto shifts
Rug_Trucker
Postby CumminsPower59 » Tue Apr 17, 2012 4:43 am
Rug_Trucker wrote:Digital cameras are a wonderful thing. Especially playing with carbs.
That is a good idea, if you can get the camera to focus that close as the marks can be a bit hard to see to begin with. I used a white paint pen, and then wiped the excess paint off when it was wet as to leave a little paint in the marks that are in the throttle shaft and the bracket.
