Head shop in Portland?
Postby wingnuts0nr » Wed Aug 15, 2007 11:52 am
I have heard of a head shop that will O-ring my head in Portland however I can't seem to find their name or contact number...
Can anyone help?
'88 GM 1T 4dr Dually with 91.5 IC Cummins KDP, P-pump all new Issapro gauges(speedo to tranny temp) HTT62-13 turbo, Injectors to come. O-ringed head by Rip, ARP head studs,Suncoast TC and Valve body...
wingnuts0nr
Postby PToombs » Wed Aug 15, 2007 4:32 pm
The only head shop I can think of is called "Up in Smoke". 8)
:lol: :lol:
Postby Begle1 » Wed Aug 15, 2007 5:19 pm
I don't get it...
I'd think Yellow Pages under "machine shop" should get you close, no?
Postby wingnuts0nr » Wed Aug 15, 2007 6:04 pm
Thanks for the input..
wingnuts0nr
Postby 2muchtq » Wed Aug 15, 2007 8:28 pm
There is sourceautomotive.biz in Milwaukie.
Talk to Rip 503-654-9004
I HIGHLY recommend them.
2muchtq
Postby wingnuts0nr » Thu Aug 16, 2007 1:21 pm
2muchtq wrote:There is sourceautomotive.biz in Milwaukie.
Thank You that was the Information i was looking for :D
called and talked with them and got schedualed for O'Rings :) so i can handle my little bit of HP
Thanks again
Barney
wingnuts0nr
Postby rbrettctd » Thu Aug 16, 2007 5:53 pm
Anybody know bout what the cost is for o-rings and studs?
Randy
rbrettctd
Postby 90firstgen » Thu Aug 16, 2007 6:15 pm
The shops I've checked at are usually between 200 and 400 dollars for orings. Plus studs by themselves are about 4 or 500.
1990 2x4, 3/4 ton, Getrag, Cummins N/I
3200 Spring
Full Fuel Screw maxed (+/- 4 turns)
Injector rebuild with bigger nozzles
1/8" Timing bump
Airflo Intake
HTT 56mm Compressor
14cm Wastegated Housing
Stan's 4"
90firstgen
Postby rbrettctd » Thu Aug 16, 2007 7:15 pm
Can you do o-rings yourself or does the head have to be machined for them? Seems like I should know this as long as Ive been hitting these sites but...
Randy
rbrettctd
Postby 2muchtq » Thu Aug 16, 2007 7:23 pm
Yessir. Tim and I were talking about o-rings and Rip.
2muchtq
Postby wingnuts0nr » Fri Aug 17, 2007 8:25 am
rbrettctd wrote:Can you do o-rings yourself or does the head have to be machined for them? Seems like I should know this as long as Ive been hitting these sites but...
No you can't O-ring your self unless you have a nice little machine shop in your back yard :) and also have to have the head milled flat (this according to rip at sourceauto) and he quoted me 350 for o-rings yesterday. and 435 for ARP studs :shock:
hope this helps
Barn
wingnuts0nr
Postby rbrettctd » Fri Aug 17, 2007 3:26 pm
Yup, a bunch. Thanks.
Randy
rbrettctd
Postby Begle1 » Fri Aug 17, 2007 4:02 pm
How often does the head need to be milled flat?
Here's a newbie question that I should now; what's the difference between O-rings and fire rings?
Postby wingnuts0nr » Fri Aug 17, 2007 4:32 pm
well I would say that anytime you O/H the head you should mill it, for better sealing and if you overheat the engine you might want to look at doing it.. and i have the same question as far as the "o-ring" vs "fire ring"
so if i find that out before someone else awnsers, I'll post it.
Barney
wingnuts0nr
Postby PToombs » Fri Aug 17, 2007 4:42 pm
Basicly, o-rings are grooves cut in the head, a piece of wire is inserted in the groove, and it crimps the head gasket tighter.
Firerings are grooves cut in the block, bigger groove, bigger wire. You need a special head gasket for these.
At least that's the way I under stand it.
By the way, a Head Shop is where you go to get rolling papers, bongs, and other druggie paraphenalia. :shock: My buddy took me to one once. :wink:
