Hansen01 wrote:if it using antifreeze yes it would be a blown headgasket but if its not in the oil and not on the ground it cant hardly be using it?? lol also have you had to drain any antifreeze for anything, could it have had bubbles in the system?
ellis93 wrote:Hansen01 wrote:if it using antifreeze yes it would be a blown headgasket but if its not in the oil and not on the ground it cant hardly be using it?? lol also have you had to drain any antifreeze for anything, could it have had bubbles in the system?
Antifreeze can run from water port to combustion chamber/piston with the engine off. This is from the cooling systems residual pressure pushing the antifreeze. If the cooling system has lots of pressure with the motor running(over say 16 or so pounds) it could mean the cylinder compression is bleeding over into the cooling system. With engine off its only natural for pressure to run back.
