radiator coolant line placement
Postby kenmartin » Fri Dec 23, 2011 9:00 am
i would like to ask for your help i have the larger bottom and top rad hoses connected, the heater core hoses connected- but am running into an issue, the vehicle that i placed the 1990 12 valve in has an overfill tank that is where coolant is added into the system, as is the radiator has no place to add coolant to, my question is it has 2 half inch nipples and 1 inch and three quarter nipple, one of the smaller is connected to the overflow of the rad, where to run the other small one? i have taken off the heat exchanger so there is 2 open spots on the bottom of the passenger side of the engine 2 spots coming out of the engine thru one opening close to the lower rad coolant hose, should i use this to attach to the rad over flow tank kinch and three quarter spot? any info i would be thankful
1990 , 80 over sticks, new head with 80 pound springs, and 4" downpipe, waiting for pullitbroke to help it be what it can be!
kenmartin
Re: radiator coolant line placement
Postby mike8061 » Fri Dec 23, 2011 9:17 am
The overflow tank needs to be connected to the barb on the rad at the fill cap. the cap only lets the coolant out once the system has reached a certain pressure. it also lets it back in when under vaccum. anywhere on the motor you hook into will be under pressuse.
92/93 W250 Ext. Cab. LP lift pump, 3200 spring, fuel screw maxed, pin almost ground through, 6" lift, flat bed, 35x12.5, big bumper
93 ext cab parted
92 reg cab parted
1967 C50 swapping in spare 5.9 auto and 205. 8.10 low in rearend. should pull somthin
mike8061
Postby mike8061 » Fri Dec 23, 2011 9:19 am
I reread your question. If i understand right your using the rad from the vehicle your putting the cummins in and it has no fitting for the overflow?
If the vehicle had the overfloe tank to start with where was it hooked to originally?
93 ext cab parted
92 reg cab parted
mike8061
Postby ellis93 » Fri Dec 23, 2011 10:54 am
Throw up a few pics of your radiator and its placement.
Postby BobS » Fri Dec 23, 2011 11:12 am
SpeedwayMotors.com sells this inline fill adapter in 1-1/2" #917-12006 @ $40. They also offer an inline air bleed valve.
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Postby u2slow » Sun Dec 25, 2011 8:50 pm
Many newer vehicles use a pressurized overflow bottle - the "rad cap" is on this bottle. No filler on the rad itself. It could be tee-ed into the cooling system just about anywhere. Just throwing another option out there...
93 W250 Club 6BTA/5spd/3.54/Dana80/~3"lift/2gen leafs/3gen wheels/HX35/5x.012s
90 D250 6BT/5spd/3.54PwrLok
84 Ramcharger [Project} D250 6BT/5spd/3.07
... various other 75-05 mopar truck products
u2slow
Postby PToombs » Mon Dec 26, 2011 6:28 pm
Ken, I reread the whole page. Run the 1 3/4 line to where ever you can, one of the heat exchanger ports is fine. Small one from the radiator overflow is fine. The other small line should go from near the thermostat housing in the top of the head to the overflow bottle. These will let air out of the radiator and block when filling. A lot of the new equipment is set up this way. ;)
Postby kenmartin » Sun Jan 01, 2012 7:05 am
thanks guys
kenmartin
