lfit pump problems?...
Postby jacobwebb57 » Thu Jan 19, 2012 5:22 pm
i finally got my fuel pressure gauge hooked up today. i got the taped banjo bolt for genos garage. i hooked it onto the main fuel line after the filter problem is my gauge is reading 1 or 0 psi at idle, truck still runs fine at low rps but after 2k there is not fueling.. i am about to buy a raptor pump anyway but just wanted to see what you guy think.. thanks
91.5 4x4 5 speed, dennyt stage 2. ddp 50 horse injectors. glow shift boost, fuel pressure, egt, autometer tach, 60lb vavle spring, 3800 gov springs, 1 ton axles, custom intake, 4'' exaust, hx35w pump turned up 3 turns raptor pump, and 1/8 timing.. new injectors sooner or later
jacobwebb57
Re: lfit pump problems?...
Postby oldestof11 » Thu Jan 19, 2012 5:26 pm
Yep. Typical stock lift pump woes.
Postby JustinRhodes » Thu Jan 19, 2012 5:28 pm
I would be careful running that, i believe that's the cause of my last ve pump not living very long.
JustinRhodes
Postby jacobwebb57 » Thu Jan 19, 2012 5:31 pm
running a raptor pump or 0 psi lol
jacobwebb57
Postby JustinRhodes » Thu Jan 19, 2012 5:40 pm
jacobwebb57 wrote:running a raptor pump or 0 psi lol
0 psi.
JustinRhodes
Postby jacobwebb57 » Thu Jan 19, 2012 5:48 pm
thats why i dont plan on driving it unless i have to...does anyone know where to get a raptor cheeper then 390
jacobwebb57
