it finally let go "head gasket"
Postby lopez dodge » Tue Mar 06, 2012 7:56 am
was leaving work yesterday and noticed a wet spot of coolant under truck, turns out im pressurizing my radiator and foaming it . backed off my timing and boost level. going to order gasket and new bolts this week. what is the benifet of going to a .10 over gasket if any?
1991.5 ..getrag super40. 40,horse injectors,4"to 6" exhaust , bhaf 2nd gen intake,custom pin timed to the head ..1/4 14.9@93mph 5,500' with a little propane
lopez dodge
Re: it finally let go "head gasket"
Postby BC847 » Tue Mar 06, 2012 8:15 am
It's my understanding that going over .010" and .020" over drops the overall compression ratio enough such as to help keep peak combustion pressures under control in the case of a higher HP engine. Obviously, the drop in compression ratio isn't a lot.
Further, dropping the compression ratio in general, cuts into the overall efficiency of the engine as well as the low-end torque.
- Don't quote me on this though.
Postby lopez dodge » Tue Mar 06, 2012 9:40 am
Found web site (agkits.com ) has resonably priced gaskets as well as head bolts.
has any one ever dealt with them or their products ?
As far as going over on gaskets, unless i find that my head needs work im going stock thickness.
lopez dodge
Postby lopez dodge » Thu Mar 08, 2012 3:16 pm
went ahead and ordered the gasket and head bolts. $133. shipped have to wait and see what the gasket looks like
lopez dodge
