Gauge sensor installations
Postby IRoss » Sun Sep 23, 2007 1:47 pm
hey there all...I'm getting ready to order some oil pressure and water temp gauges from isspro, but I'm having trouble figuring out where the sensors are going to be mounted...can I use a T-adapters in the stock sensor location to retain the stock sensor, or are there aux. ports that I'm missing on the block..what type of thread should I order?....I was planning on using electrical sensors on both, aside from the price, does anybody have an opinion on the accuracy of mech.vs.elect?
thanx, ian :?
91.5IC 4x4 5spd extra springs
valet, 190s, ,18cm, 4"ëxh.
H4 conversion w/relays
rwal mia w/prop. valve
IRoss
Postby gomerpile » Sun Sep 23, 2007 2:43 pm
there is a plug on-top of the oil filter, it is 1/8 npt, but im not sure on the water temp. and personally i like mech gauges over electric but the mechs need snubbers in them or they will die quickly, and also i dont like the idea of hot oil in the cab that the gauge/piping can get cut/burst and i dont like the idea of oil in the cab with electricity.
1992 Dodge D-250 LE auto, LSD w/3.54, about 200,000+ miles.Isspro Pyrometer , Sunpro tach,Tractor Supply Boost Gauge, Old Smokey Fuel Pin,4 turns on fun srew, starwheel turn CCW 1 turn, 40hp injectors, BHAF,16 cm housing.Sony Head Unit.
gomerpile
Postby IRoss » Sun Sep 23, 2007 2:53 pm
Yeah, I forgot about that one, I suppose that would be 1/8"?...Now, anybody out there with a water temp gauge care to share their sender mounting secrets....
IRoss
Postby PToombs » Sun Sep 23, 2007 5:13 pm
Pipe plug on top of the head next to the current sender. You know, next to the valve cover! :wink:
Postby BEARKILLER » Sat Sep 29, 2007 5:33 am
McMaster-Carr has nice stainless 1/8"NPT ball-valves that should be plumbed into the mechanical fuel-, and oil-pressure, gauge-lines.
With these valves, the gauge-line can be easily shut-off, in the case of line failure.
They also have the correct snubbers.
Someone else can post the link; as, this site doesn't hardly let me post, without me having to log in a dozen times.
#4 = 1991 D-350 LE Getrag
BEARKILLER
