Racing a 80's cutlass supreme with a 350
Postby cummins32 » Fri Dec 14, 2012 11:28 pm
There's a kid I know that has a cutlass, that has a 350 in it, with headers, cherry bombs, holley 4bbl, and an intake. He thinks it's the hottest thing around. I'd really like to shut him up. He'd Sh** his pants if he got beat by a truck. My mods are in my sig. What are my chances of beating him ? Also, a 4wd boost launch at what psi ?
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Re: Racing a 80's cutlass supreme with a 350
Postby oldestof11 » Sat Dec 15, 2012 5:44 am
Boost until the tires don't hold. But i don't think a boosted launch is needed for a gutless.
Postby bmoeller » Sat Dec 15, 2012 7:24 am
Having an auto, you might have a chance.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby cummins32 » Sat Dec 15, 2012 8:04 am
I know I can get im off the line, I just dont know about top end. it quits fueling around 90
cummins32
Postby Mark Nixon » Sat Dec 15, 2012 4:47 pm
Take it to a dragstrip, otherwise if you lose your driver's licence over it, we don't want to hear about it. :roll:
Postby Sutter1stgen » Sat Dec 15, 2012 6:37 pm
What turbo do you have? What sized tires? What are your current egts?
What year is his cuttless? What cam and intake manifold does he run? What stall does he run?
There are alot of variables that will make a difference. a well tuned small block can sound as tame as can be, and in a light platform can suprise alot of people. My uncle owns a 70' chevy 3/4 ton 2wd with a small block. He's the original owner, has all the paperwork. Truck has a 2 barrel fueler on it with a stock engine (probably rebuilt by now). That truck is quiet and fast! Not to mention heavy.
Eric
Sutter1stgen
Postby dunes450r » Sat Dec 15, 2012 8:12 pm
chances are low of beating it. especially if it is tuned at all, and the driver is ok. a car that ways 2000lbs+ less, with as much or more horsepower doesn't sound good
dunes450r
Postby ellis93 » Sat Dec 15, 2012 8:25 pm
Unless that dude has a good size bump stick in it or a stall converter/gears combo I'd think your truck would hang with it at least. if your truck stays with it then it'll show him he's not "fast"
Postby cummins32 » Sat Dec 15, 2012 11:00 pm
I've got a stock turbo that builds 31lbs, my egts are around 1450 pinned, I've got 285/75/16 bg goodrich all terrains on it. His car has a stock cam and stock trans, and is by no means tuned he thinks tuning it is just turning random screws on the carb that he chooses. He knows nothing about engines at all.
cummins32
Postby cmann250 » Sun Dec 16, 2012 6:58 am
It's safe to say that you could benefit from a lift pump. With a low pressure piston pump, mine pulls hard until I run out of gear somewhere above 85. I don't have O/D.
My key to victory is get the left lane :lol:
Postby Sutter1stgen » Sun Dec 16, 2012 11:12 am
cummins32 wrote:I know I can get im off the line, I just dont know about top end. it quits fueling around 90
90? Wound out in o/d?
I think you'll take him in the begining. But you need to figure out your top end fueling.
Eric
Sutter1stgen
Postby cummins32 » Sun Dec 16, 2012 11:57 am
Ya, it doesn't pull much past 90. It might pull a little more since the injectors but I need a fuel system, I think I'm running out of fuel
cummins32
Postby bubba » Sun Dec 16, 2012 7:01 pm
A chevy 350 was never offered in the supreme. A 350 Oldsmobile was available in the 442 and hurst/olds. 305s and 307s were put in em though. So if it has a chevy 350 it is not the factory motor and could be pretty hot. Could be being the deciding factor.
1992 Dodge W350 CTD A518 DRW Flatbed
bubba
Postby VanillaGorilla » Mon Dec 17, 2012 1:14 am
Just try it, his junk could go 15's or he could have a half way decent hustle going. Who knows.
Here's what I grudge/street race, I only claim cam and intake. Stock bottom end, stock iron heads.
http://www.youtube.com/watch?v=SNR4ELAoM6o
That one cost me some damn $$$$
93 Reg cab LE 4x4 518AT, 145k and counting, pump turned up,Internal pump mods, Denny T stage 2, non IC DV's, timing bumped up, BD 40hp injectors,BHAF and me-built mandrel bent CAI,4" turbo back, Holley lift pump, new white with gold paint job, recieving more mods to tow the Duster and push this stupid WI snow.
VanillaGorilla
