injectors maybe??
injectors maybe??
Postby 1990CTD » Sat Jan 26, 2013 9:48 am
Well a couple of my injectors are bubbling around the base. Well i also have fuel coming out of my manifold gaskets on the same injectors that leak. Would this make it white smoke alot when cold?
1990CTD
Re: injectors maybe??
Postby cougar » Sat Jan 26, 2013 11:43 am
Just being cold will cause it to white smoke. I'm sure a compression leak isn't helping. The copper seals are easy to replace under the injectors. While you have them out give them a good bath. There are many other problems that can add the the white smoke. Fix what you know and carry on from there.
01 2500 "the work truck".
cougar
Postby galakinokis » Tue Feb 19, 2013 2:37 pm
Well tighten those suckers down! i got a new reseal kit for my new injectors. didnt cost much
galakinokis
