72 mph out of a 92 with a g360
Postby Crb12_89 » Sun Jan 27, 2013 6:39 pm
My stock 92 has 160,xxx 4x4 no muffler fuel pump turned up 1.5 turns will only go 72mph on a good day down a hill pedal on the floor does anybody know why????
Crb12_89
Re: 72 mph out of a 92 with a g360
Postby dazedandconfused » Sun Jan 27, 2013 6:48 pm
Could be gearing but i bet your sucking the lift pump dry and starving it for fuel.
Postby Crb12_89 » Sun Jan 27, 2013 6:51 pm
How can I fix that w/o buyin a new one. Or is there no way to fix it
Crb12_89
Postby Crb12_89 » Sun Jan 27, 2013 6:52 pm
It only turns about 18-2000 rpm when I've got iT floored and the turbo won't spool
Crb12_89
Postby dazedandconfused » Sun Jan 27, 2013 6:53 pm
Upgrade lift pumps. Which pump will determine use and power output of truck. Welcome by the way snd post up some pics of your truck.
Postby Crb12_89 » Sun Jan 27, 2013 6:55 pm
Thanks I'm trying but I'm new to this forum
Crb12_89
Postby dazedandconfused » Sun Jan 27, 2013 6:56 pm
Well have you checked the turbo? Does it blow black smoke heavy and never clear up? Could be a boost leak or junk turbo if its not spooling but my bet is going to be lift pimp. How does it run going threw the gears? Do you hit a spot and it noses over or is it a dog all the time?
Postby dazedandconfused » Sun Jan 27, 2013 6:57 pm
Link in my sig shows how to post pics.
Postby RCCUMMINS89 » Sun Jan 27, 2013 6:59 pm
If turbo won't spool, might have a boost leak. do you have gauges?
At 2000rpms, you might not be getting full throttle travel.... also stock gov. spring only allows 2500. Do you have a tach to actually know your rpms?
Postby Crb12_89 » Sun Jan 27, 2013 7:11 pm
It runs good and stout it smokes but cleans up quick thanks again
Crb12_89
Postby dazedandconfused » Sun Jan 27, 2013 7:14 pm
Does it nose off hard when it stops pulling?
Postby ellis93 » Sun Jan 27, 2013 7:15 pm
My ol'truck wouldn't do 84 before the 3200 gov spring,that's with the 4.10's. Your running out of fuel plain and simple. ;)
Postby Crb12_89 » Sun Jan 27, 2013 7:24 pm
No I don't have any gauges or a tach that's just a guess a guy that's a well known diesel mech. Around here also said. It might have a gov on it
Crb12_89
Postby Crb12_89 » Sun Jan 27, 2013 7:26 pm
How bad is a bigger spring to put in and where can I find one. The truck is supposed to have 3.55s
Crb12_89
Postby dazedandconfused » Sun Jan 27, 2013 7:37 pm
My bet is your lift pump is toast. My truck with a weak lift pump, 27" tires and 3.55 gears will pull to 90 before hitting the governor wall on my stock pump. After about 80 it pulls real slow due to lack of lift pump pressure.
