Fuel Transfer Pump (lift pump) upgrade
Postby monoblock » Wed Feb 06, 2013 2:29 pm
I am trying to be logical about this first step in upgrades so have avoided putting this post in the "make it go faster" section. Really I don't want more speed-I just want it to go more reliably and more the way Clessie Cummins (rather than the Dodge Bros. accountants) would have wanted.
There are many recommendations for a modest upgrade to the OEM Delphi diaphragm (fuel lift)pump. I mean a mechanical or electric pump that will support other upgrades that may eventually produce roughly 20-30% more power/torque.It should also improve reliability,reduce leaks .It would give a consistent pressure of 12+ psi? I have read so much my head is spinning with all the alternatives. Can anyone rank the alternatives by manufacturer & part number for reliability/effectiveness? My muddled impression from all the opinions is that the Cummins(not Delphi/Dodge pump) is the smartest choice -but which one and what pressure?
Some of the candidates are:
The Walbro GSL392, aka 255LPH. The similar Holley and generics of the same design(made in China?)
This is a useful link because it graphs the performance of the Walbro pump:
http://www.ebay.com/itm/230906992478?ss ... 1423.l2649
Cummins Fuel Transfer Pump ? Cummins Part Number:3936320 . Interchange #: 4944714,4988751 $65 on EBay
Hungry Diesel's tweaked pump (what part number/what tweaks?) $265 +core
The HFP701 or HFP 700 piston pumps-big difference in price between these two part numbers.
Then there are little mods with shims,gaskets.
It would be brilliant if someone could boil this down to just a list of 1 pump and a shim !
monoblock
Re: Fuel Transfer Pump (lift pump) upgrade
Postby RCCUMMINS89 » Wed Feb 06, 2013 4:10 pm
The Hungry Diesel (me) has a factory 2nd gen style pump #4988747, genuine cummins lift pump and all cummins parts needed to put it on.
The pump has a different internal regulator spring in order to meet the psi output that our pumps require.
This pump has a larger piston than the Cummins low pressure lift pump, and has a larger piston and higher psi than the delphi lift pump.
If you want to stay mechanical, this is the best route.
Postby rockmike » Wed Feb 06, 2013 4:10 pm
http://www.thehungrydiesel.com/Lift_Pump.html
Good guy,lots of knowledge,the correct pump! call him up.
93 d350 extra cab 5 speed dually.
Mods: hx35,rotated fuel pin,bosch 190 inj.,BHAF with smooth intake tube,3200 rpm spring,M&H dynamic timing spacer,isspro EGT and boost gauge,Auto meter tach, fuel press. gauge.Diamond eye 4" exhaust,Sno Stage 2 W/M kit.
Real trucks dont use spark plugs!
rockmike
Postby rockmike » Wed Feb 06, 2013 4:13 pm
Ha Ha ya beat me to it.
rockmike
Postby oldestof11 » Wed Feb 06, 2013 4:43 pm
I loved my Walbro. Make sure you regulate it. I used a Mallory 4307M.
Postby RCCUMMINS89 » Wed Feb 06, 2013 5:02 pm
monoblock wrote:Hungry Diesel's tweaked pump (what part number/what tweaks?) $265 +core
Core? no core charge.... all of our parts are new.
Postby cmann250 » Wed Feb 06, 2013 5:12 pm
I have a Cummins low pressure piston pump and I'm happy with it. I suspect I'm beyond the 30% additional power, so it should meet your needs just fine.
I'm a wheeler dealer, so I got a new Cummins pump for less than they list for. However, if I were to do it again, I'd buy the pump RCCUMMINS makes. His prices are extremely competitive and I've seen alot of good reviews of his product.
Postby PToombs » Wed Feb 06, 2013 6:12 pm
It's getting really hard, and really expensive, to find the correct cummins low pressure LP anymore. Most of what is sold claiming to be the correct one is no good or wrong. If I was going to buy one today I would buy one from Eric. (hungry diesel) I prefer to stay with a mechanical pump, less electric headaches. ;)
Postby monoblock » Wed Feb 06, 2013 9:16 pm
I read several tech articles by Tork Technology . One of the well argued cases he makes is for a much larger diameter inlet pipe from the tank to the transfer pump ,remove the 'necks' and 90 degree fittings where possible.Perhaps that should be part of the upgrade?
http://forum.mopar1973man.com/threads/2 ... 12V-owners
monoblock
Postby RCCUMMINS89 » Wed Feb 06, 2013 9:25 pm
Yep... anything to reduce fuel system restriction.
I run a 3/8" supply and 5/16" return..but everything else stock. I should upgrade the sump tube (inside the tank). Larger banjo bolts, and even an upgrade hard lines (lift pump to filter and filter to injection pump) as well as larger filter all increase the volume of flow that a lift pump can move as well as makes it easier for it do it's job.
Postby DodgeFreak » Thu Feb 07, 2013 7:37 am
I'm running a hplp with mallory regulator. I went this route because I was/am debating pee pumping one of my engines.
Postby revemup15 » Thu Feb 07, 2013 8:32 am
Since eric has sumed up all the basics not much good info left to say besides, I have a piston pump from eric and its great... cheaper than dap for there junk piston pump kit and its a genuine cummins pump which has a bigger piston (for more volume) than the leading competion expensive junk kits out there. Give eric a call you wont regret it
94 p-pump
revemup15
Banned
Postby monoblock » Thu Feb 07, 2013 9:20 am
RCCUMMINS89 wrote:Yep... anything to reduce fuel system restriction.
Thanks for this practical confirmation . It seems Tork Technology had a good point in the articles linked above.
monoblock
Postby monoblock » Thu Feb 07, 2013 9:03 pm
I found a Big bore upgrade kit for latter models but it gives some ideas for our 1st Gens?
http://articles.mopar1973man.com/genera ... g-line-kit
Related, I found an interesting article on improved fuel filtration using a "CAT" filter.It is adaptable(?) to our trucks perhaps:
http://www.cumminscatfuelfilter.com/
monoblock
Postby DodgeFreak » Fri Feb 08, 2013 6:13 am
You can install it. You need the filter head\s. I've got two filter heads and a filter and water seperator to install on mine. I'm still debating to put mine inbetween the pump and the tank or inbetween the pump and injection pump.
