Mark Nixon wrote:I've mentioned the differences several times.
If you search, you'll even see where I have mentioned it.
In actuality they ARE the same tachs, just the plug is different.
As you can see the connector pins are even the same shape, just the plug housing is different.
Just remove the housing and connect them to the OEM harness the same way Autometer does with theirs.
BTW, the 1989 and MOST 1990 engines DIDN'T come with notches in the damper for the tach to read off of, either.
RCCUMMINS89 wrote:But now everybody knows bill has at least 2 tachs
DodgeFreak wrote:I had an 89-91 tach in my 92 before i sold the tach, I just made jumper wires for it. Seemed to be right.
