The best injectors for a good fuel economy?
Postby Oskar » Wed Apr 03, 2013 1:11 pm
Hi. i will change all the injector nozzles when i get my truck, i like to give my diesels fresh nozzles and set the pump timing right. but i know that there is several types of aftermarket nozzles for these engines, so i would like some advice on what type to use? i want good quality (bosch or equivalent) and most important is good fuel economy and high torque, what should i choose? and do you recommend setting them at specified opening pressure, or slightly higher (for better fuel atomization, of course advancing the pump a few degrees will be necessary too)
the truck is a W250 1992 with auto trans
Oskar
Re: The best injectors for a good fuel economy?
Postby RCCUMMINS89 » Wed Apr 03, 2013 2:06 pm
Stay bosch, I've recently done testing on aftermarket nozzles and they are not up to par to say the least.
Bosch 190s, 5x10-5x12 size, if low miles nothing wrong with the stockers.
How much power are you looking to gain while doing it?
Postby Oskar » Thu Apr 04, 2013 9:29 am
Hi and thanks for the answer!
are those you mention the stock ones? how about the non-intercooled injectors, heard that they are better to use.
power gain isn't as important as fuel economy, but if both can be combined, i would prefer a 30-40hp increase.
Oskar
Postby dazedandconfused » Thu Apr 04, 2013 9:48 am
You can't put a non intercooled injector in to a intercooled head. The non ic injector I has a larger diameter nozzle. There may be a way to turn it down but I can't be for certain.
Postby CumminsPower59 » Thu Apr 04, 2013 11:05 am
The non-ic sticks can be turned down on a lathe, there was a picture of som floating around on here quite a while back...
Postby dazedandconfused » Thu Apr 04, 2013 11:14 am
I thought so but wasn't sure enough to say it could be.
Postby ellis93 » Thu Apr 04, 2013 11:41 am
CumminsPower59 wrote:The non-ic sticks can be turned down on a lathe, there was a picture of som floating around on here quite a while back...
I believe that was Jon that did that
Postby Oskar » Thu Apr 04, 2013 2:06 pm
Ok, thanks so far! I have a lathe so that won't be any big deal, how much larger are the older nozzles?
and, is it a good idea to choose them, or is there any better choice that fits without modification?
Oskar
Postby dazedandconfused » Thu Apr 04, 2013 2:08 pm
Non ic are 9mm and ic are 7mm.
Postby CumminsPower59 » Thu Apr 04, 2013 3:46 pm
Ellis, now that I think of it, it was Jon that had those.
Anyways, all I know is that if I were in the market for some new, efficient injectors, I would be trying some new, Bosch 190's.
Postby RCCUMMINS89 » Thu Apr 04, 2013 3:53 pm
Bosch 190s can be had for brand spankin' new for $420 with no core charge..... and the vast majority that have used them say they are the best for economy and they do increase power about 30hp.
Postby kwrank » Thu Apr 04, 2013 6:45 pm
oskar--how much do you pay for fuel in sweden?
92 W250 CC HX35/16 366 190's lp piston lift hughes converter
kwrank
Postby Rob_O » Thu Apr 04, 2013 7:00 pm
RCCUMMINS89 wrote:Bosch 190s can be had for brand spankin' new for $420 with no core charge..... and the vast majority that have used them say they are the best for economy and they do increase power about 30hp.
Interesting. Tried honing a set to see how they take to modifications?
Rob_O
Postby RCCUMMINS89 » Thu Apr 04, 2013 7:17 pm
No, but I've read about guys doing it and I think they opened up to like 48 or 50lpm. Personally if I was trying to get more fuel out of a 190 I would just go with a larger injector and then possibly flowing that. It's kind of like flowing a stock injector out, but paying 600+ for it (420+flow work). Usually when someone wants more fuel they want to go quite a bit bigger.
Postby Oskar » Fri Apr 05, 2013 7:25 am
seems like these injectors are exactly what i need. is it possible to buy only the nozzles somewhere?
Oskar
