S300G
S300G
Postby Horicon93 » Wed Apr 10, 2013 6:42 am
I picked up a new/used turbo last night. On the phone the guy told me it was a S300G, but I get there and the intake housing says HX40. He swore to me that he had it measured at a reputable shop and the measurements are the same as the S300G that I want ( 57/65/14). Are there any casted numbers I can look at to confirm this, or do I need to take it to a shop to get measured again?
'93 Extended Cab, DRW, 2WD, Auto, 4 1/2" stacks, Bone Stock
Horicon93
Re: S300G
Postby RCCUMMINS89 » Wed Apr 10, 2013 7:36 am
Does it have a 3 or 4" exhaust flange?
Re: S300G
Postby Horicon93 » Wed Apr 10, 2013 7:59 am
4" OD
Horicon93
Re: S300G
Postby RCCUMMINS89 » Wed Apr 10, 2013 8:11 am
well.... then I'd measure it and see. Use a tape measure and you can get an approximate. 5.7 cm and 6.5 cm for the wheels you can see. Is it w/g?
Re: S300G
Postby Horicon93 » Wed Apr 10, 2013 8:45 am
To the best of my abilities they appear to be 60/65. It's w/g. My other concern is that on the turbo-to-manifold flange it is stamped & cast with a 19... is that the housing size?
Horicon93
Re: S300G
Postby RCCUMMINS89 » Wed Apr 10, 2013 8:57 am
Yep.... sounds like it's a hx40 to me.
Re: S300G
Postby Sutter1stgen » Wed Apr 10, 2013 9:05 am
If a guy told me over the phone that a turbo was a X, and I got there with my basic knowledge and saw that it was actually turbo Y, I think I would be pretty confident in myself walking away. Especially when he used the excuse " it measures out the same". Be patient and make sure you get the right product, it will make the difference in weather or not you have a good running truck, and enjoy this sport.
Eric
Sutter1stgen
Re: S300G
Postby Horicon93 » Wed Apr 10, 2013 4:48 pm
Sutter .... <sigh> ... Thanks for kicking me while I'm down. :)
Horicon93
Re: S300G
Postby Sutter1stgen » Wed Apr 10, 2013 9:31 pm
I was joshin on the X and Y thing. I don't like seeing people get screwed over.
I had a friend receive way off advise one time and it upset and discouraged him so bad he almost gave up his project. Cost him quite a bit. Glad to see you took my humor well.
Eric
Sutter1stgen
