intake horn
intake horn
Postby RedneckCumminsLover » Tue Nov 12, 2013 7:58 am
ok im new to the hole diesel world but I caint seem to find an aftermarket intake horn for my 1990 D250
:? ideas?
thnks
RedneckCumminsLover
Re: intake horn
Postby Tacoclaw » Tue Nov 12, 2013 9:59 am
Re: intake horn
Postby Tacoclaw » Tue Nov 12, 2013 10:08 am
Also, I've read about a later model horn that is almost a direct swap. There's actually a set of pics and a thread about it on here somewhere, either BGilbert or Philip put it up. I always get them confused on here.
Here, I typed "air horn" into the search, this was like the third thread listed.
viewtopic.php?f=1&t=14645&p=129154&hilit=Air+horn#p129154
Re: intake horn
Postby RedneckCumminsLover » Tue Nov 12, 2013 12:29 pm
Thank you
RedneckCumminsLover
Re: intake horn
Postby AHineman » Tue Nov 12, 2013 6:01 pm
I think Tim stopped making the coolertubz. :(
Re: intake horn
Postby Mckinney » Thu Dec 05, 2013 11:03 pm
I dont mean to hijack the thread but thought it would be appropriate here. Is it worth upgrading the intake horn on a non I/C truck? or would it be more valuable to spend the money by adding an intercooler then upgrade the intake horn?
Mckinney
Re: intake horn
Postby CumminsPower59 » Sat Dec 07, 2013 9:43 am
Add an intercooler...
Re: intake horn
Postby Mckinney » Sat Dec 07, 2013 8:14 pm
Spin off question: worth adding a first gen, second gen, or go for the powerstroke intercooler?
Mckinney
Re: intake horn
Postby DMan1198 » Sat Dec 07, 2013 9:32 pm
Second gen or powerstroke ic yes. 1st gen no
I've read it's easier to add a second gen ic to a non ic'd truck than an ic'd truck. Since you have to cut either way I don't think it matters. Both have aftermarket units available if you decide more than stock is needed
Re: intake horn
Postby CumminsPower59 » Mon Dec 09, 2013 11:48 am
I went with a 2nd gen IC myself, as my 91 was NON-IC. It was pretty easy to install, just took a little cutting here and there, relocating the coolant overflow jug, trimming the battery tray, etc. Not hard at all ;)
