Stage 2 Nozzles
Stage 2 Nozzles
Postby 92cummins89 » Fri Nov 22, 2013 7:53 pm
Lookin at buying these Nozzles are Stage2 +75HP (330hp) 5x0.011 Performance nozzles
Wondering wat y'all suggestion are
92cummins89
Re: Stage 2 Nozzles
Postby RCCUMMINS89 » Fri Nov 22, 2013 8:04 pm
What year is your truck?
Re: Stage 2 Nozzles
Postby 92cummins89 » Fri Nov 22, 2013 9:14 pm
92 ic
Nv4500
He351cw
92cummins89
Re: Stage 2 Nozzles
Postby RCCUMMINS89 » Fri Nov 22, 2013 9:23 pm
5x11 SAC would be a perfect fit for that turbo. (assuming you don't want more fuel later on, etc.)
Just make sure they are a 145 degree angle and not a true "330" as those are a marine injector and a 155 angle.
If you don't mind me asking.......what is the manufacturer or company selling them?
Re: Stage 2 Nozzles
Postby 92cummins89 » Fri Nov 22, 2013 9:38 pm
Where can I get the 5x11
From diesel auto power
92cummins89
Re: Stage 2 Nozzles
Postby RCCUMMINS89 » Fri Nov 22, 2013 9:59 pm
DAP stick SHOULD (emphasis on should) be the proper spray angle...it will simply be an aftermarket nozzle.
Otherwise....I sell the genuine Bosch 5x11 SAC injector for $400 plus core of $100.
The difference between the aftermarkets and genuine bosch is the quality in the steel. Just like how we all notice that Chinese steel is of poorer quality....so is the aftermarket injectors (which are Chinese made). Won't tell a difference in how they perform....except the longevity of the nozzle will be different. These things are very noticeable when one does extrude hone and/or edm work on the nozzles. The Chinese ones definitely show that there is more inconsistency in them.
Re: Stage 2 Nozzles
Postby 92cummins89 » Fri Nov 22, 2013 10:44 pm
Thanks for the insight
U ever heard of exergy? I know they do honing etc. lookin at getting my dmax a injectors done there
Was actually thinking of sending them my injectors for them to hone ?
92cummins89
Re: Stage 2 Nozzles
Postby RCCUMMINS89 » Fri Nov 22, 2013 10:53 pm
Yep.... I've used exergy. I have another builder that does only hone work for me as well.
Pm me if you want to talk about a possible package deal on the dmax injectors and your current ones.
