aftermarket fuel screen ?
Postby jethro » Fri May 01, 2015 11:02 pm
My engine only has a single fuel filter.(stock) I have installed the 2-nd gen piston pump.
I am wondering if it is a good idea / desirable to add some type of fuel screen unit in the line between the fuel
pump and the tank. I have seen ones for boats and also one made by goldenrod sold at northern too which I think is for using
in the line of a dispensing tank/nozzle when you have an aux off road diesel tank. would that work ?
I would think you would want something with very low resistance to flow- drainable with a quick drain- and something you can
take apart to clean or inspect the screen occasionally.
Any popular units to recommend ?
Tim
jethro
Re: aftermarket fuel screen ?
Postby Hansen01 » Sat May 02, 2015 4:04 am
There's already one for catching big stuff in the tank, if you want more most people add a fass or air dog for the extra filtration
Under construction...
Hansen01
Postby comotionman » Sat May 02, 2015 2:39 pm
Baldwin bf1173
coupla trucks non & ic, 2nd gens, various other
comotionman
Postby 762frmafr » Wed May 06, 2015 7:46 am
Been running the GoldenRod filter for 48 hours. So far so good. I will update the below thread with progress.
viewtopic.php?f=1&t=16681
762frmafr
