cummins king wrote:yes but you have to have alot of fuel moving through it to keep it lubed and cool, you will also need very large injectors to move the fuel, when i have mine up and running again, it wont be a daily driver, but a every other day toy
ford69557ci wrote:after hundreds of runs on the test stand mine still looks like new i think the key to keeping one together is a good high flow fuel supply system and large enough injectors to keep all of that extra volume moving. I even ran 10 test with some injectors set at p pump pressures and it didnt hurt the h&r any but it also had no improvement on flow.
swank wrote:i've been driving my quite a bit over the last two years. not a single problem. at least other than that runaway. that didn't have anything to do with the head though. i can attest to it being capable of 5000 rpm though.
