fuel pump leaking at throddle shaft
Postby grumpy » Wed Aug 13, 2008 3:51 pm
where too order throddle shaft and bushing's for my fuel pump got a real bad leak?? snoot you be quiet..lol.
93 dodge w350 excab daully auto 3600 gov spring 4" streight pipe,hx-35/40 turbo
91 jeep xj trail rig I-6 5spd exo cage 7inch lift
87 35ft gooseneck trailer soon to have 79camper on it.
grumpy
Postby gear jammer 91" » Wed Aug 13, 2008 4:43 pm
when mine was leaking there, I got my seal kit from source auto. I don't remember the part number but any good diesel shop should be able to get the seal kit. The kit doesn't come with the bushing, there is an o-ring on the throttle shaft, that's what was bad on mine, and the o-ring was in the kit. Hopefully somebody's got the part number. You could try looking for the part number in the sticky over an dtr.
01 LB7
gear jammer 91"
Postby grumpy » Wed Aug 13, 2008 5:10 pm
so should I replace the shaft???was quoted $81.75 for the shaft and bushing kit..
grumpy
Postby PToombs » Wed Aug 13, 2008 5:31 pm
If you don't need the truck to drive right away, I'd pull the cover and check the shaft. Remove the shaft, pull the o-ring. Put the shaft back in, see how much slop you have. A lot of times you can check it right on the truck. Mine was good, so I just changed the o-ring. If the shaft is out, you can see the wear.
If the bushing needs to be changed, my shop likes to put it in an oven to cook the epoxy they put on the bushing. Some places just keep the cover overnite to let it set up.
Postby SNOOT » Wed Aug 13, 2008 6:39 pm
My lips are sealed...
1993 W350
SNOOT
Postby grumpy » Wed Aug 13, 2008 9:17 pm
oh snoot what ya doing this weekend...lol.
grumpy
Postby SNOOT » Wed Aug 13, 2008 9:35 pm
I have to work... :(
1993 W350
SNOOT
