Fuel shutoff solenoid problem solved
Postby Brutus_Marcus » Fri Aug 15, 2008 12:02 am
Here are a couple of photographs of a mico bosch pump used with the Cummins6BT around these parts of the world. Seems like they already had an idea about the leaky fuel shutoff solenoid, so they just hooked up the solenoid directly to the manual lever. Wonder why Dodge cummins never did this....
Also, i remember somebody talking about the exhaust brakes not being compatible with non-wastegated Turbos, but here almost all the 6BT's have the non-gated hx35's with the exhaust brakes, and that too on 35ton trucks.
Bikram
Brutus_Marcus
Postby Ace » Fri Aug 15, 2008 7:29 am
What part of the world we talking about, Bikram? Just about anything is compatible with anything if you can find the right parts or make them yourself. :P
Ace
Postby Brutus_Marcus » Fri Aug 15, 2008 8:06 am
Here are the pics,
Made by MicoBosch, India
Brutus_Marcus
Postby PToombs » Fri Aug 15, 2008 5:40 pm
That looks more like it's hooked to where the KSB should be. Hard to tell in the pic. Must be a lever activated timing advance!
Postby dpuckett » Sat Aug 16, 2008 3:26 pm
Pete, the KSB would go where the diamond is in the lower left corner of the picture. The RPM timing advance works without the KSB; the KSB just shoves the advance piston over when cold (or switched on). Looks like a different lever for the manual shut off, then the solenoid attached to the rear bracket, right below where mine is bent over to gain access to the Dodge solenoid.
Daniel
Postby Ace » Sat Aug 16, 2008 3:39 pm
I can't see why they would do that. Take something simple and reliable, make it complicated and less reliable.
Ace
Postby Brutus_Marcus » Sat Aug 16, 2008 11:01 pm
heard the orignal solenoid has problems handling high pressure. The rubbers seal around the shutdown pin wears off with high pressure. Thats why lots of ppl with hotrodded fuel injection pumps use the manual lever for shutdown.
Brutus_Marcus
Postby fergavs » Mon Aug 18, 2008 7:17 am
Looks to be the same solenoid used on the P-pump. http://www.dieselperformance.com/index. ... /index/41P
fergavs
Postby apwatson50 » Mon Aug 18, 2008 8:17 am
From the bosch VE manual it is a:
"Mechanical cold-start accelerator (KSB), advance mechanism with automatic operation
(cold-start position)"
page 41
Aaron
92 Cummins, 4x4, 270K miles
apwatson50
Postby Brutus_Marcus » Mon Aug 18, 2008 1:56 pm
well, its hooked to the top lever, the one with 5033 stamped on it. Quite difficult to make out in the pictures but thats the way it comes here. Pitty most of the ppl change the ve for the 'A' pump here. Running costs of the 'P' pump are just to high, and the 'A' is absolutely bulletproof. Its used to haul 25ton trucks so low rpm stock springs are the norm.
Brutus_Marcus
