stock head bolt retorque, non-I/C
Postby gear jammer 91" » Wed Aug 20, 2008 5:36 pm
I've been reading about re-torquing head bolts to hold 40psi better, and read that the non-I/C trucks have different head bolts and that they need to be torqued differently, or shouldn't be re-torqued at all? Does anybody now anything about this?
01 LB7
gear jammer 91"
Postby fasttalker83 » Wed Aug 20, 2008 6:04 pm
everyone I talk to says 125ft lbs is max and ive done it on my 90 with no problems
fasttalker83
Postby cummins king » Wed Aug 20, 2008 7:59 pm
i did 125 and i have held 55psi and im going for 60 pounds :evil:
93 4X4 auto
cummins king
Postby gear jammer 91" » Wed Aug 20, 2008 8:48 pm
In case I have one that stretches, does dodge have new bolts? or would I need to go cummins for one?
01 LB7
gear jammer 91"
Postby rattlebox93 » Tue Aug 26, 2008 9:06 am
id go to cummins anyway dodge is way to proud of there cummins parts!! generaly 1/2 the price at cummins
rattlebox93
Postby gear jammer 91" » Tue Aug 26, 2008 4:14 pm
thanks thats good to know as I ma be needin some other parts. :?
01 LB7
gear jammer 91"
Postby gear jammer 91" » Sat Aug 30, 2008 4:46 pm
I finally re-torqued my head bolts. All went well. I did notice that the top of the bolts had a T+<180 marking on top of them. I'm guessing that's torque plus 180 degrees? I thought the non-intercooled trucks had straight torque bolts? Anybody got any thoughts?
01 LB7
gear jammer 91"
Postby PToombs » Sat Aug 30, 2008 5:01 pm
That's correct, it should be torque only on non- I/C . And on the newer ones, it's torque + 90*.
Don't know what's up with the marks on the bolt head. I hope you didn't go that much! :shock:
Postby gear jammer 91" » Sat Aug 30, 2008 10:56 pm
I took em' all to 100 foot pounds and called it good. I'm only plannin on runnin 40 pounds through it with my new turbo.
01 LB7
gear jammer 91"
