Softer AFC Spring?
Softer AFC Spring?
Postby cedardiesel » Mon Sep 29, 2008 3:22 pm
Is there a softer AFC spring that i can get cause i got the Blue one and it is pretty dang stiff I would like to find a spring were when i'm at 4-8 lbs of boost i'm at 100% fuel instead of bein close to 15-20 lbs for full fuel
90 W250 4x4 5spd pump Ve cranked wide open, BHAF, HX35 with all 2.5" intake piping, and 4" straight piped
92 W250 4x4 5spd P-pumped B1B over B2 are on and now slippy clutch
cedardiesel
Postby gear jammer 91" » Mon Sep 29, 2008 8:43 pm
Their is a spring that is softer, I believe it is silver and that it came in the later year intercooled trucks. Have you adjusted the star wheel yet?
01 LB7
gear jammer 91"
Postby Makaio » Tue Sep 30, 2008 12:08 am
The red/green spring IS the softer spring. The silver one is stiffer. Like gearjammer mentioned, turn your starwheel down and see it runs.
Aloha,
Matt
1992 W250 auto, ASA/AFE intake, H1C hybrid 60-16, Bosch 190's, Bully Dog fuel pin, 366 spring, modified pump and a 4" turbo back exhaust. Suncoast valve body plumbing 3.54's w/LSD. Autometer gauges.
Makaio
Postby cedardiesel » Tue Sep 30, 2008 7:02 pm
I've already got the starwheel bottomed out but do yall know of any place to get the red and green spring
cedardiesel
Postby fergavs » Wed Oct 01, 2008 11:43 am
Probably from bosch.
fergavs
Postby cedardiesel » Fri Oct 03, 2008 4:19 am
alright thanx
cedardiesel
