engine poping and sputtering!
Postby rattlebox93 » Thu Oct 16, 2008 10:12 am
i started my truck this morning drive to town and it was fine when ileft my moms house i started it up and it was kinda hard to start and was ideling low i reved it up and i was popping i reved it a few times and it cleared up i went to my shop filled it up with fuel started it and again it did the same thing i held it aginst the governor for a few seconds and i cleard up do i have a injector going bad and bleeding off or what??? what do youguys think
rattlebox93
Postby TWorline » Fri Oct 17, 2008 6:29 pm
Sounds like you are getting air in your fuel system. Could be your supply line or your fuel pump going south.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby rattlebox93 » Mon Oct 20, 2008 9:32 am
thanks tim. when u say fuel pump im hoping u meen lift pump? rite lol i noticed last lime i had my pump top off i tried the priming lever on the lift pump and it diddent work! so i just bought a fass system for it so if i am getting air to the injection pump that should take care of that. also what press do the ve pumps like the fass has a 14lb spring in it now is that too much? i also got a set of 435 edm's coming! the guy at new era thought it was an injector so im going big lol im either gonna melt her or make some power also i waxed her up and got so pics of her for ur site or whatever ill hafta get ur email and get em too ya
rattlebox93
Postby TWorline » Mon Oct 20, 2008 5:26 pm
Yeah I meant lift pump. 14# is okay, my piston pump puts out 16# and have had no issues with the front seal. Here is my eMail TNTSound@tds.net
Tim Worline
TWorline
