Solid Motor Mounts
Solid Motor Mounts
Postby MrHorsepower » Sat Mar 14, 2009 7:44 pm
Anyone running solid motor mounts? Any complaints with vibrations? I am building a second set, and I am thinking about building solid mounts. I am sure the Chevy mounts will collapse from the Cummins. I have the mounts from the donor truck, but no crossmembers or anything.
Any thoughts?
Bob
In Progress: '84 Chevy Silverado dually w/19.5 rims.
1st gen, New Eras, s300, 366, DennyT, piston LP, Pacbrake, 60lbs. springs, ARP studs, Snow Perf. stage II, '97 DR IC, 4" stacks.
NV4500, 14 Bolt Locker & Dana 60 Posi w/3.73's
MrHorsepower
Postby KTA » Sun Mar 15, 2009 9:20 am
I would recommend rubber mounts for a daily driver. Solid mounts transmit a lot of vibration and are harder on the engine block because there is no give. With no give the block now becomes a structural component of the frame and in high flex operations could overstress the block as it tries to keep the frame from twisting.
Postby MrHorsepower » Sun Mar 15, 2009 9:35 am
I was worried about vibration and ride quality, never thought about what it would do to the block. I will try and use the Dodge mounts to fab up new mounts.
I have seen conversion mounts for $350-500. Figure I can build a heavy set much cheaper.
MrHorsepower
Postby seeker1056 » Mon Mar 16, 2009 4:52 am
i used the dodge mount and a piece of 1/2" rubber sandwiched between the mount and frame due to clearance issues.
Works well and is as close to solid as one can get
Vibration is minimal
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
