Grid heater delete
Grid heater delete
Postby Bad93Cummins » Sun Jan 24, 2010 8:35 pm
Is it worth it? Does it do anything mileage or perfromance wise?
Bad93Cummins
All you'll see...
Postby ZSkibo » Mon Jan 25, 2010 4:03 pm
All you'll most likely see are slightly lower (50 degrees maybe) EGT and boost due to better flow of air. Nothing that you'll feel driving. Oh, and harder starting if your low temps are under 30. That said, I don't run my heater in the summer time (just cuz) but it's not really a performance mod. Just eliminates battery drawdown on starting I guess.
92 W250 Pump bombed, AFC out, 366 spring, 18* timing, KSB hotwired, HX35 12cm non wg, New Era 6x18's, BHAF, 60 lb in/ex springs, 4" PAC Brake, onboard air, Nathan P3 horns
ZSkibo
Postby Bad93Cummins » Mon Jan 25, 2010 9:16 pm
well I live mid-eastern florida so not very often does it reach 40, lol
Bad93Cummins
Postby Richie O » Mon Jan 25, 2010 9:24 pm
Bad93Cummins wrote:well I live mid-eastern florida so not very often does it reach 40, lol
O sure, rub it in while I freeze 1800 miles north of you. :evil:
Postby Bad93Cummins » Mon Jan 25, 2010 10:02 pm
sorry bud, lol Don't mean to rub it in, just seeing if its worth the time to delete them or not.
Bad93Cummins
Postby Richie O » Mon Jan 25, 2010 10:42 pm
Where you are so far south, it may be a smart thing to do. If you do end up with big injectors and it does get cold you will miss your grid heaters.
Postby Mark Nixon » Tue Jan 26, 2010 12:16 am
I have a stock Cummins grid delete around here somewhere.
Too cold for them here.
Postby Bad93Cummins » Tue Jan 26, 2010 7:47 pm
So do yall think I should delete them? ill be in houston, texas for about a year and a half doing the diesel and diesel industry program at UTI and then the Cummins elective program over their but then coming back to florida, so should I take the time to delte them or just leave them?
Bad93Cummins
Postby doublel89 » Tue Jan 26, 2010 8:03 pm
If you ever get a job in the rockies you'll want em!
91 3/4 Ton 4x4, 5.9 Cummins,DDP Fuel Pin I usually leave it out though, DDP 40 Horse Sticks, HX35W And 2nd Gen Intercooler, Single 5'' Trunout, NV5600 Swap, Dually Conversion, 3.08 Rear Gears, Soon A Custom Hauler Bed
doublel89
Postby DieselSharker » Tue Jan 26, 2010 9:17 pm
Bad93Cummins wrote:So do yall think I should delete them? ill be in houston, texas for about a year and a half doing the diesel and diesel industry program at UTI and then the Cummins elective program over their but then coming back to florida, so should I take the time to delte them or just leave them?
When do you start?? I start March 29th.
1991 W250 727, 6" Skyjacker, 37" Dick Cepeks, Gear Vendor O/D, SDX 5x.014s, BHAF, home-made 4" intake, VE tuning & DennyT II pin, GDS 60mm with 16 cm, CoolerTubz 3" crossover
SUPPORT YOUR VETERANS!
DieselSharker
Postby Bad93Cummins » Wed Jan 27, 2010 4:36 am
09/13/10
Bad93Cummins
Postby DieselSharker » Wed Jan 27, 2010 10:53 pm
Good deal. I'll probably be done with the auto part by then. i'm doing auto/diesel/industrial. Just look for the big red & white thing in my avatar. Shoot me a pm if you need somebody to show you around.
DieselSharker
Postby Bad93Cummins » Thu Jan 28, 2010 5:01 am
Will do man!! That'd be cool be in the same class their man. Ya my plan is doing diesel/diesl industry/cummins electrive prgram, work for cummins for 5-8 years then open up my own shop.
Bad93Cummins
Postby DieselSharker » Thu Jan 28, 2010 11:14 am
I'm probably gonna end up doing the same thing. After Cummins I'll probably try to get a job fixing generatorson oil rigs or work for the railroad. BNSF heavily recruits vets and I've talked to one of their recruiters and he said I shouldn't have a problem getting a job with them. They pay very well and I believe it's also a union job. Anyway...didn't mean to hijack the thread, carry on lol.
DieselSharker
Postby Bad93Cummins » Thu Jan 28, 2010 1:13 pm
Yea man Im excited to go and start off strong doing the thing I love doing, working on trucks and diesel's and owning my own shop.
that sounds like a hell of a plan man!!
Bad93Cummins
