conversion
conversion
Postby Power Ram Man » Tue Jun 12, 2007 5:12 pm
i was wondering how much it would cost (an estimate) to convert my auto tranny to a 5 speed
92 3/4 Cummins with coverted getrag 5 speed, 4x4 PODS,3200 Gov spring,16cm housing, 4inch exhuast homemade downpipe, water meth,hx35 turbo,5 inch stainless intake with AFE filter, fuel turned up, timing bumped boost,pyro guages, Denny T fuel pin,coolertubz,piston lift pump
Power Ram Man
Postby dpuckett » Tue Jun 12, 2007 8:59 pm
I looked into it a few years ago, and it would have been upwards of $2500. But, if you find a good used tranny, with all the attachments, I know of a few parts trucks you can get pedals from. You MIGHT be able to get by with it for $1500.
You can likely build your auto for what it would cost to convert it to shift from the right place.
Daniel
Postby BHD » Sun Jun 17, 2007 6:28 am
I had about 2K in mine, that was with new clutch and an overhaul on the getrag.
1990 W250, 185K, 727 to G360 conversion, 3.07's to 4.10's, straight piped, BHAF, 2.5" Skyjacker springs, Autometer gauges, 285 Cooper STT's,
BHD
Postby rbrettctd » Mon Jul 23, 2007 8:04 pm
BHD wrote:I had about 2K in mine, that was with new clutch and an overhaul on the getrag.
Mine started at $600, but with a rebuild and a new clutch, I just finished it up at about the same $2k.
rbrettctd
Postby PToombs » Tue Jul 24, 2007 4:38 pm
Pepecat on TDR did his for $1500.
Postby mhuppertz » Mon Jul 30, 2007 5:39 pm
It's worth every penny IMHO.
mhuppertz
