freeway boost
Re: freeway boost
Postby thrashingcows » Thu Nov 24, 2011 10:47 am
My D350 crewcab, with 89 motor is all stock....164K miles. Cruising at 65mph I see about 2-5lbs boost, and my post turbo EGT is around 450-475 degrees. This is with my NV4500 in 5th, and 3.54 rear,
thrashingcows
Re: freeway boost
Postby cougar » Thu Nov 24, 2011 11:37 am
Different conditions.
I put my winter front on last weekend cause my thermostat wouldn't stabilize.
Cruising across the hay flats at 55, -4°, stiff head wind.
Boost came up to 12psi and egt to 800° in 5th.
Thought my engine was trying to quit until I looked at the boost.
01 2500 "the work truck".
cougar
Re: freeway boost
Postby tampabayBill » Tue Nov 29, 2011 8:25 am
At an actual 70mph (confirmed by GPS), 600egt and 5lbs. boost, tach at 1900 rpm.
Twins coming soon!
tampabayBill
Re: freeway boost
Postby ahale2772 » Thu Dec 01, 2011 7:02 am
after my cam swap my freway boost came down to 5psi at 75mph 8)
