running cool.
Re: running cool.
Postby dazedandconfused » Sun Dec 11, 2011 5:54 pm
I'm pretty sure my thermostat is stuck open. I drove it around for about 2 hours today and pulled my radiator cap off and stuck my finger in the radiator and it was barely luke warn. I did this after feeling the hoses.
Re: running cool.
Postby PToombs » Mon Dec 12, 2011 6:35 pm
Start it up and see if the water is circulating.
Re: running cool.
Postby dazedandconfused » Mon Dec 12, 2011 7:02 pm
I did it while it was running and it wasn't circulating which I thought was strange. I pulled over off the interstate ramp after a 9 mile 80+ mph run flogging on it and it wasn't hot. Never hear the fan engage either. My temp sensor is broke but as hard as I was running it there should have been some heat.
Re: running cool.
Postby oldestof11 » Mon Dec 12, 2011 7:09 pm
How does the head behind the rear valve cover feel?
Re: running cool.
Postby dazedandconfused » Mon Dec 12, 2011 7:23 pm
Never felt it. The antifreeze was warm as tap water and has been everytime I've checked. I'm gonna pull it apart and replace the thermostat.
Re: running cool.
Postby ahale2772 » Tue Dec 13, 2011 5:22 am
thats how mine feels too, engine is honestly not getting hot. FWIW my headgasket had all sorts of goo on the small water passages, almost plugged.
need to flush system...
Re: running cool.
Postby dazedandconfused » Tue Dec 13, 2011 5:48 am
Yeah I flushed mine 4 times when I first put it together to try and avoid this issue. While my truck was in pieces I flushed and cleaned everything.
Re: running cool.
Postby ahale2772 » Mon Dec 19, 2011 4:52 am
Now have the colling fan off the truck, replaced the temp guage and sender, piece of cardboard completly blocking off the radiator. took a ride yesteady (30* day), bout 25min on the highway, temps never got over 165 :(
Re: running cool.
Postby Hansen01 » Mon Dec 19, 2011 5:48 am
mine only gets up to about 170 in the winter time, with the radiator blocked by cardboard, workin now on some stainless steal winterfronts for all my short trips:D
Under construction...
Hansen01
Users browsing this forum: No registered users and 57 guests
