KSB wiring on 89, any experts?
Re: KSB wiring on 89, any experts?
Postby Ed ke6bnl » Sun Nov 02, 2014 6:00 pm
PToombs wrote:Nice banjo bolt in the AFC top. :lol: Looks like somebody had a problem with it.
Was missing on the motor, order a
8x1x17mm banjo with washers, hope it all fits correctly
Ed ke6bnl
Postby CumminsPower59 » Sun Nov 02, 2014 8:31 pm
If by chance it doesn't since the threaded insert in the AFC cover are buttered up, drill it out and tap it for 1/8" NPT. Remove the hard line and elbow from the head and use two 90deg 1/8" NPT to 1/4" air line. Get a short section of 1/4" air brake line and use that. Then, you won't have to mess with it down the road if you want to fiddle with pump timing adjustments, as it'll be flexible ;)
Not a good picture, but you can see the looped 1/4" line.
Postby Ed ke6bnl » Sun Nov 02, 2014 9:07 pm
great idea I have used the quick disconnect fitting on the air bag on my 50 F1 pu and that stuff is nice to work with that is a GREAT IDEA.
Ed ke6bnl
Postby Tacoclaw » Mon Nov 03, 2014 4:46 am
Considering that "plug" looks like it's left hand thread, I'm gonna assume it's plenty buttered up. :lol:
Postby PToombs » Mon Nov 03, 2014 6:30 pm
Yeah, it looked left handed to me too, but I'm getting old and thought my eyes were seeing it wrong. ;) I finally swapped mine to all NPT fittings and hose too. The swivel I had blew apart so I got all new fittings and hose and replaced it all.
