by hassy21 » Mon Apr 09, 2012 4:19 pm
Hey just got that part and put new stock filter and the part which fit really well. Primed the truck and it started rite up with no leaks may I add. The truck wouldn't start before I changed filter and fuel heater. Let it run for awhile and thoughtthat everything is ok and the got two small flutters when idling around 10 min. Then took it down the street and got on it seemed fine then on my way back got on it and it fell on its face then started fluttering as if it was running out of fuel or sucking air because truck is and was still running. It seems like it surges more under a load. Just wondering if it could be my fuel line or pickup tube that is cracked. I'm hoping that its not lift pump or injection pump but I figured if one of those gave up that it just wouldn't run not run sometimes or flutter like my truck is doing. Any help appreciated.
