Headgasket Thoughts
Re: Headgasket Thoughts
Postby quickie70 » Sun Apr 22, 2012 10:21 pm
^^^ agree with this. you could flush it, but a heater core is a "stacked plate" design, and not a bunch of rows of tube, so sometimes the flush will only flush the top 1/4" of the heater core. if you eliminate it completely, it'll help narrow down the culprit, but if it's actually getting hot, the heater core will have little to no effect on the engine cooling, but it will have an effect on a poorly placed sender. Put a mechanical gauge, even temporary, in the bung next to the thermostat and check it out.
1991.5 RCLB 4x4 LE Rag w/ 3.54's 200,000+ miles, original denny T, WH1C, P/S I/C with coolertubz, pump turned up slightly, DDP stage 1's, gauges (lots of em). Custom Anti-Rusting-undercarriage 15/40 coating provided by leaky timing cover. 306 HP / 599 TQ.
quickie70
Postby bmoeller » Mon Apr 23, 2012 6:18 pm
Mark is right. The sender location has a lot to do with the temp swing on the needle. 2nd gen trucks do it as well. Cooling system is far more than adequate to keep the engine cool. That is why the needle is steady with a load. It is normal, and nothing to worry about, overall. If you have coolant loss issues, then I'd be concerned.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby ahale2772 » Mon Apr 23, 2012 6:46 pm
I did a headgasket on my truck, and a few of the smaller holes had weird gooo bound up around them, also Backflowed the heater core and the radiator, made absolutly no difference, truck was actually running cool, and still is cold blooded
Postby xohcef » Wed Apr 25, 2012 6:52 am
Alright so I guess I'm just going to have to have some faith in the trusty ol cummins. The temp gauge and how it acts is the least of my worries now. I have had a nightmare of an electrical problem come up and now the temp gauge is not reading right anyway along with a few of my other gauges/lights freaking out at me.
93 d350 extended cab dually, NV5600, he351cw, DDP stage 3, industrial man ported, ported head, 60# springs, 354 spring, holley blue, aeromotive fpr, South bend single disc/hydros, kelderman dual bag.
xohcef
Postby ahale2772 » Thu Apr 26, 2012 7:43 pm
throw A mechanical guage on there, ifen if you just tie wrap it somewhere simple to use it as a reference to see if the stock on is accurate
Users browsing this forum: No registered users and 63 guests
