took pump apart....now no start
Re: took pump apart....now no start
Postby Deathrod » Sat Apr 28, 2012 10:11 am
I think I may have found the problem.....after I put the top half of the pump back on the manual shut lever moves fine, try to start it then the lever won't close....it hits something, but what I don't know.
Deathrod
Postby Deathrod » Sat Apr 28, 2012 3:59 pm
Well me and a buddy spent all day, took fss apart and put it in gutted, nothing seems to be wrong with it, gets good spray at injector lines. We are stumped. Any ve gurus in SoCal that want to check this thing out? I threw in the towel, everything checks out and should work
Deathrod
Postby 1arock » Sun Apr 29, 2012 12:35 pm
Have you tried cranking it with the throttle held open? That will rule out the throttle shaft being indexed wrong. Ther splines are so fine and my eyes are so old about half the tome I get it on wrong. Rocky
92W250 w/a 68D100 skin,tach, pyro, boost, trans temp guages, rebuilt a518 w/a PTC converter, 4in muffeled exhaust, 3200 gov spring, he351cw,M@H dynamic timing, 5x12s,M@H M3 pin, pump jacked with, 3.54s, 6+ lift, 14.5x36r rubber,nearly done,"What was I thinking?"
1arock
Postby Deathrod » Sun Apr 29, 2012 6:40 pm
Ya I tried everything I could possibly think of, everything I read, still nothing.....I'm gonna have to break down and take it somewhere i think....never had to do that before :x
Deathrod
Postby PToombs » Mon Apr 30, 2012 4:56 pm
Just out of curiousity, when you put the spring in and the top on was the arm on the throttle shaft pointing towards the head? Or the fender? It should be toward the head. Sometimes they get swapped around and nobody notices, and they have starting/ running issues.
Postby Deathrod » Mon Apr 30, 2012 7:31 pm
Yes it's pointing towards the head, I don't think it will go in the other way.
Deathrod
Postby PToombs » Tue May 01, 2012 5:13 pm
Oh yes it will. :lol: Somebody posted that when they stepped on the throttle the idle went down, they had it in backwards.
Just figured I'd ask, trying to cover all the bases. ;)
Postby Deathrod » Tue May 01, 2012 7:46 pm
Hmm seems like it would hit the side of the pump....but I guess u could squeeze it in the way. I'm going to try to take it somewhere tomorrow that specializes in ve pumps.....hopefully they don't send me to the poor house :oops:
Deathrod
Postby Deathrod » Wed May 02, 2012 5:11 pm
Bent fulcrum lever was the culprit. Looked like a factory bend it in to me, but the guy picked up on it quick. Uniteddiesel.com is a shop here in CA that came highly recommended for working on the ve pump. Talked to the owner about prices of having a pump rebuilt and they seemed pretty fair for the quality of work. If anyone needs some work done you can ship your pump and they will take care of it, just tell them the guy with the 5.9 Model A sent you, ask for Justin he'll take care of you!
Deathrod
Postby dazedandconfused » Wed May 02, 2012 5:23 pm
Glad to hear you got it running.
Users browsing this forum: No registered users and 65 guests
