which injectors?
Re: which injectors?
Postby ellis93 » Sun Mar 10, 2013 3:55 pm
Check out this item I found on eBay:
End time: Apr 3, 2013 12:59:27 PM
Item: 16cm Exhaust housing BD Dodge Diesel Cummins Turbo WH1C
URL: http://pages.ebay.com/motors/link/?nav= ... 0706067582
Alt URL: http://www.ebay.com/itm/16cm-Exhaust-ho ... 0706067582
(Sent from eBay Mobile for Android)
Postby RCCUMMINS89 » Sun Mar 10, 2013 4:00 pm
ellis93 wrote:The 16cm housings you can pick up for 160$ just about any where. Check out Ebay,I've seen them on there
I carry them as well. For $151.00
Postby blackvmax07 » Sun Mar 10, 2013 5:19 pm
will i notice a power difference goin to a 16mm? Wat exactly do i have stock? Sorry for all the questions im new to the cummins thing. Am i better off changing the housing or doin an hx35? Thanks for the help fellas
blackvmax07
Postby ellis93 » Sun Mar 10, 2013 5:25 pm
It's either 18 or 21cm,the number is cast in the housing around the outlet.
Postby blackvmax07 » Mon Mar 11, 2013 5:22 pm
Ok ill look, I was looking at maybe just doin the hx35, is that a good upgrade? Where can I get a new one? Iv hears of people getting the Chinese ones so im sceptical on where to get it
blackvmax07
Postby cmann250 » Mon Mar 11, 2013 6:38 pm
I really like my HX35. It's probably my favorite mod and it's essentially drop in. On the air side, it's just a bit of an upgrade, but the 12 cm exhaust housing is very much of an upgrade over the 18 and I suspect a night and day difference over the 21 cm exhaust housing.
I gave $80 for mine and swapped it in without doing anything. I'm adventurous :lol: I'm beginning to believe that even the true blue Holsets are from China, but I can't prove it. :?
Postby RCCUMMINS89 » Mon Mar 11, 2013 6:44 pm
An hx35 is essentially the same thing (slightly better) than your h1c with a 12cm housing.
Postby blackvmax07 » Mon Mar 11, 2013 9:08 pm
Ok thats wat ima get then, do I need to but the hx35 new or can I find one at a junk yard?
blackvmax07
Postby RCCUMMINS89 » Tue Mar 12, 2013 8:36 am
Go with a used one. If you are going to pay the money for a new one, there are better turbos to buy for not much more. LIke a Super B for about a grand, or a 60/68 for a touch more
Postby apexfd » Sat Jun 01, 2013 9:19 pm
How do people like the he351cw on stock injectors for towing?
apexfd
